Date/Time: Tue, 04 Mar 2025 03:53:29 +0000
Getting a 'caught in unhandled exception' in c_chart
View Count: 555
[2021-11-22 22:58:09] |
ayush arya - Posts: 42 |
hey guys getting this weird error when trying to load BTCUSD from Binanca or Bifinex. It was working until yesterday. can you help? attached is a pic of error. |
[2021-11-23 04:31:50] |
This exception is related to graphics output. If you are using OpenGL, disable it: Graphics Settings: Use OpenGL for Chart Graphics (Global Settings >> Graphics Settings >> Other) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-11-23 04:46:29] |
it isnt enabled on my sierra charts. so maybe thats not the issue. thanks for your help.
