Date/Time: Tue, 04 Mar 2025 03:26:38 +0000
Set different price increment for TPO and VBP
View Count: 410
[2021-11-22 18:59:56] |
User845653 - Posts: 9 |
I am using a daily TPO with a Volume by Price based on the TPO, is there a way to set a different price increment for the TPO and vbp? For example I'd like to have my TPO with a letter price increment of 4 ticks and my vbp with a 1 tick volume increment. I know I can set the vbp to be independent from the TPO but then it's not possible to display a vbp for each day. |
[2021-11-23 04:20:15] |
No, this is definitely not supported. It would never be supported. You need to use separate charts. Each configured as you require.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-11-23 04:20:20
