Date/Time: Tue, 04 Mar 2025 03:33:44 +0000
[Programming Help] - Select/apply using "Studies Settings" is causing unexpected results.
View Count: 597
[2021-11-22 16:04:26] |
User92573 - Posts: 547 |
Dear Support I currently have a number of studies that use auto-looping and basic counting. What I am noticing is that if I right-click a specific study's subgraph, then "Studies Settings" and press apply, those other studies using "bar counting etc." increment their count by 1. If I do either of the following: 1) Select "insert", it as expected, resets the count to the correct "Bar 1" for the first bar on the chart. 2) Right-click and select "Studies" and just press "apply", it also resets the charts count to the correct "Bar 1" for the first bar on the chart. If I use the Right-click and select "Studies" followed by "apply" then it will on some charts produce the above unexpected outcome. The issue impacts "all charts" and not just the one I am "applying" on. Many thanks. Date Time Of Last Edit: 2021-11-23 12:38:37
[2021-11-23 17:57:51] |
One thing to consider is that when you reload the chart, all of the Study Subgraph arrays are cleared. So you need to make sure you are not reusing the values in the Subgraph arrays in case they are not cleared. This is an issue that you must solve on your side. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-11-23 17:58:09
