Date/Time: Tue, 04 Mar 2025 03:35:14 +0000
Issues with order rejection
View Count: 515
[2021-11-22 15:43:56]
PlainCheesePizza - Posts: 17
It seems every time I go to flatten an order I am getting an error. This happen while I am in a bracket order trade, when I hit flatten I get an error in the log and it closes my stop and target orders but does not close my position. I then have to hit flatten again in order to exit my position.
New order rejected - Rejected by Transact. Internal Order ID: 17677. Service Order ID: 49955869. Symbol: NQZ1. Account: xxxx| 2021-11-22 09:06:14.739 *
NQZ1[M] #4 | User order entry | Unable to Flatten/Reverse. Position does not exist | Symbol: NQZ1 | TradeAccount: xxxx| 2021-11-22 09:06:16.778 *
MNQZ1[M] #19 | User order entry | Unable to Flatten/Reverse. There are working Market orders that will flatten the Position. Working non-market orders will be canceled | Symbol: MNQZ1 | TradeAccount: xxxxx| 2021-11-22 09:09:01.744 *
MNQZ1[M] #19 | User order entry | Unable to Flatten/Reverse. Position does not exist | Symbol: MNQZ1 | TradeAccount: xxxx| 2021-11-22 09:09:02.325 *
New order rejected - Rejected by Transact. Internal Order ID: 17695. Service Order ID: 49957104. Symbol: NQZ1. Account: xxxx| 2021-11-22 09:37:23.400 *
[2021-11-22 15:55:25]
Regarding this, refer to:
Basic Trading and the Trade Window: Rejected Market Order When Using Flatten or Reverse Because of Position Limit Exceeded (Rejected Market Order When Using Flatten or Reverse Because of Position Limit Exceeded)
[2021-11-22 16:22:16]
Thank you that did the trick
[2021-11-22 16:28:46]
This issue is not a problem with our new Teton Order Routing service. So the command to cancel orders and flatten can all be sent at the same time for the lowest latency with closing a position.
Full documentation for that service,
