Date/Time: Tue, 04 Mar 2025 03:50:13 +0000
numbers bar
View Count: 540
[2021-11-22 15:27:42] |
User318521 - Posts: 47 |
hello my numbers bars is giving me sporadic volume, what can fix this thanks https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=57270 |
[2021-11-23 15:09:16] |
John - SC Support - Posts: 38341 |
The only thing we can think of is that some of the coloring for your Text is set to the same as the Background, which is causing the numbers to not appear. If this is not the case, then attach a copy of that chart by following the instructions at the following link for us to take a look: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
