Date/Time: Tue, 04 Mar 2025 12:18:22 +0000
Study Subgraph Above/Below Bar as Text
View Count: 1100
[2021-11-22 15:14:18] |
User749673 - Posts: 23 |
Dear Team Presently Text is drawn above the high or below the low of bar . I would like to draw the text at last price( close) or at open price by using Text in the right side of candle stick body or left . |
[2021-11-23 15:05:26] |
John - SC Support - Posts: 38341 |
We have set this as a feature request. Or, you can modify the source code, as this study is available in the file Studies8.cpp in the ACS_Source directory under your main Sierra Chart folder. Refer to the following: https://www.sierrachart.com/index.php?page=doc/HowToBuildAnAdvancedCustomStudyFromSourceCode For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-12-03 02:53:56] |
Dear Mr John I am not able to modify in source code . I am not a programmer . Kindly release the feature request |
[2021-12-03 15:31:03] |
We do not know when we will be able to get to this request. We recognize it as something that could be useful that multiple people would want, but we do not know when or if we will be able to get to this specific request. This is true for anything that we put into this category.
[2021-12-05 11:22:05] |
Dear Mr John, When candle or number bar price ( say for ex 30 min time frame) is moving down very fast,Text display in the Top of the bar is hidden in the screen as price moving down below the screen bottom . I find it little frustrated . If the display is kept in "Right side or left side of the candlestick body at last price it will be visible .Hope you understand my concern.Thanks |
[2021-12-06 16:21:25] |
Certainly, we understand why you want to do what you are asking. It's just that when we tag something as a Feature Request is just means that we have it on our list of a change to make. We do not know when we will be able to get to the change.
[2021-12-09 09:33:32] |
Dear Mr John, Thanks for your message that feature request has been added to your list . I do have study collect file with some alert formula. Can I convert into .dll file so that others cant see what is inside . Thanking in advance for your Reply |
[2021-12-09 15:53:22] |
Yes, you could do this. You could do the code so that it is just doing the Alert and getting the data from the studies that are on the chart. Or, if you want to replicate the studies, most of the studies have the source code available, but there are a few that do not (like Numbers Bars, Volume by Price, or TPO) for which you would have to access the underlying data to get what you need. In general, the information for creating ACSIL studies starts at the following link: Advanced Custom Study Interface and Language (ACSIL): Introduction You also stated that you are not a programmer, so here is a list of programmers that we know of that can put together a custom study for you: List of Third Party Sierra Chart Study and System Programmers For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
