Date/Time: Tue, 04 Mar 2025 03:24:22 +0000
All charts replay pauses when market closes
View Count: 432
[2021-11-22 10:08:57] |
User785723 - Posts: 58 |
When I replay E-mini Nasdaq-100 with "All Charts in Chartbook" mode, the replay pauses for a long time at 5 pm ET on Fridays which is the time when the market closes. This cannot be solved even if the "Skip Empty Periods" option is selected. |
[2021-11-22 13:57:07] |
Reduce the replay speed. Refer to: Replaying Charts: Automatic Skipping of Periods Where There Is No Trading and Synchronization Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
