Date/Time: Tue, 04 Mar 2025 03:50:25 +0000
USDT from Bitmex - how to add new crypto pairs?
View Count: 586
[2021-11-21 11:22:40] |
ULADZIMIR VALASACH - Posts: 38 |
Now there are 9 coins on the Bitmex exchange for trading through USDT (https://www.bitmex.com/tether) - and in SierraChart there is only one coin DOGE - how to add the rest?
[2021-11-21 16:09:08] |
We see 8 symbols which are active with this in the symbol name: USDT-BMEX Refer to step 7 here for instructions to access them: Cryptocurrency / Bitcoin Data and Trading Services: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-11-21 18:55:22] |
it turned out - thank you!
