Date/Time: Tue, 04 Mar 2025 03:51:25 +0000
Problem with real time EUREX data from IQFeed
View Count: 566
[2021-11-19 20:01:11]
User733806 - Posts: 3
Problem:
I get the following error message
“Download Failed
Historical data only supported with Sierra Chart data feed”
Background:
I subscribe to IQFeed’s EUREX data feed and I believe I have correctly connected to IQFeed
How I get the error message:
I click
File->Find Symbol
I select Futures - EUREX BLZ21 (Euro BOBL)
I select “Open Intraday Chart”
A Chartbook opens with a black screen
At the bottom it says
BLZ21 1 Min #1
What I want
Real time intraday chart for EUREX data from IQFeed
[2021-11-19 21:56:08]
John - SC Support - Posts: 38341
In order to get EUREX data from a 3rd party, you need to be on Sierra Chart Package 10, 11, or 12. In your case, this would be Package 11 (equivalent to Package 5).
We have gone ahead and given you 30 days of Package 12 evaluation, this will allow you to get the EUREX data. Just keep in mind that at the end of these 30 days, you will need to change your package to Package 11 to continue to get the features you want and the EUREX data from IQFeed.
Date Time Of Last Edit: 2021-11-19 21:57:29
