Date/Time: Tue, 26 Nov 2024 02:15:05 +0000
V 1077 Apex DOM
View Count: 1020
[2014-04-02 00:04:46] |
Fozdick - Posts: 35 |
Having problems with Apex DOM. Still using V 1077 which works great. You/we had so many problems I went back. I noticed that the Trade Service log came up when I got a Trade Order Error today. Could updating to later versions affect the DOM? Is it safe to used later versions with OEC now? |
[2014-04-02 00:14:10] |
Everything is stable now with OEC in the latest versions. OEC has quietly resolved the outstanding issues. We are not aware of any depth problems in the latest versions when using OEC, so updating may very well resolve the problem. All order errors will be displayed in the Trade Service Log. So it is normal for that to open. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
