Date/Time: Fri, 22 Nov 2024 03:23:50 +0000
Moving chart horizontally
View Count: 1848
[2013-04-24 13:01:56] |
MMX - Posts: 119 |
I upgraded from v948 to v967 and am no longer able to left click & hold and move the chart horizontally. All scrolling options in Global Settings/General Settings are set to enable scrolling. What do I need to do to get this function back?
[2013-04-24 18:41:46] |
You need to use the Tools >> Hand tool.
