Date/Time: Mon, 03 Mar 2025 22:41:34 +0000
Symbols needs Rollover
View Count: 506
[2021-11-17 15:15:33] |
User390757 - Posts: 1 |
Buenas noches tengo una inquietud , trato de abrir un grafico especificamente del crudo pero me aparece este mensaje, (Symbols Needs Rollover), intento cambiar el contrato pero no me lo cambia, intente abriendo otro chartbook pero de igual manera no cambia el contrato a diciembre 21, les solicito ayuda para solvertar este problema muchas gracias
[2021-11-17 17:03:45] |
John - SC Support - Posts: 38341 |
From Google Translate: Good evening I have a concern, I try to open a chart specifically for crude oil but this message appears, (Symbols Needs Rollover), I try to change the contract but it does not change it, I tried opening another chartbook but in the same way it does not change the contract to December 21, I ask for your help to solve this problem, thank you very much
When the window opens after you select the option for Click to Rollover you need to select the pulldown to the right and select the contract you want to roll-over to. Refer to the following documentation, which includes an image of the window showing where to select the contract: Changing to a New Futures Contract Month: Changing to a New Futures Contract Month For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
