Date/Time: Wed, 23 Sep 2026 10:19:24 +0000
Duplicate chart to chartbook is not working for me
View Count: 810
| [2021-11-17 13:58:00] |
| auggie - Posts: 45 |
Hello, I used to be able to use this command to copy a chart to a different chartbook. Now instead of giving me an option to choose the chartbook I want it copied to it gives me these options none of which copies the chartbook to the other chartbook. .jpg attached. Thanks |
| [2021-11-17 14:05:07] |
You need to left click twice on where it has the Chartbook name to edit that from a drop-down list. Refer to: Settings Windows Interface: Item List (Working with Sierra Chart Windows >> Selection Specific Options) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
