Date/Time: Mon, 21 Sep 2026 00:58:37 +0000
Can you run sierra charts using a dial up connection?
View Count: 1330
| [2014-04-01 18:34:54] |
| User37129 - Posts: 15 |
Hi there, I tried searching all over Google for what the minimum internet connection is for connecting with Sierra Charts, I simply want to know if I can successfully use a dial up connection to run Sierra charts. Thank You, BF |
| [2014-04-01 18:38:10] |
Yes, as long as you are tracking only 1 or 2 symbols. In the case of a dial up Internet connection, make sure the Global Settings >> Data/Trade Service Settings >>Intraday Data Storage Time Unit is set to 1 Minute. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
