Date/Time: Mon, 03 Mar 2025 22:15:13 +0000
Offset Candles
View Count: 795
[2021-11-16 20:54:23]
User628616 - Posts: 132
How do I offset the candles to the left of the numbers so there is a small gap between them? And also can I make the numbers plot 'Bold' so they stand out more.
imagezaz.PNG / V - Attached On 2021-11-16 20:51:55 UTC - Size: 36.8 KB - 196 views
[2021-11-16 21:52:35]
John - SC Support - Posts: 38341
It is not possible to offset the bars.
The interesting thing is that the image you show is not from our Numbers Bars study. If you are using a 3rd party study then you would need to ask the developer of that study how to do things like bold the test or place the numbers in a position where you can get some space from the bar.
[2021-11-16 23:11:51]
It is in the Studies List: VolumeByPrice indicator by yall
[2021-11-17 15:04:11]
Sorry, we thought it was the Numbers Bars, but it did not match our Numbers Bars, with good reason apparently.
Still, it is not possible to Bold the numbers, but you can change the size. Refer to the following:
Volume By Price Study: Volume Numbers Text Color and Size (SG7)
