Date/Time: Fri, 27 Nov 2026 23:07:58 +0000
Study/Price Overlay
View Count: 1119
[2021-11-16 20:52:55]
User841161 - Posts: 357
I was trying to chart a study(1 Divided By Price Study)from chart#3 onto chart
#4 buy using study/price overlay. But chart is displaying overlay on price correctly.
Is there a setting that is incorrrect?
http://www.sierrachart.com/image.php?Image=1637095596961.png
https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=57039
imageStudySettings.11-16.png / V - Attached On 2021-11-16 20:51:15 UTC - Size: 178.54 KB - 404 views
[2021-11-16 21:47:04]
What you are seeing is just a scaling issue. You are trying to display two different sets of data in the same range - the ES and the 1/6E. The ES prices are around 4700 whereas the 1/6E is around 0.883.
The easiest solution is to make the Study/Price Overlay an Independent scale, and you can also use the left side scale to view the values. Refer to the following:
Chart Scale and Scale Adjusting: Independent (Scale Range)
And refer to the following for the Left Side Scale:
Chart Settings: Use Left Side Scale (Chart >> Chart Settings >> Scale menu)
