Date/Time: Mon, 03 Mar 2025 22:30:59 +0000
SYMBOL FOR MICRO 30-YEAR YIELD FUTURES
View Count: 530
[2021-11-16 20:43:50]
User41636 - Posts: 35
PLEASE PROVIDE YOUR SYMBOL FOR THE MICRO 30-YEAR YIELD FUTURES CONTRACT. THANK YOU
[2021-11-16 21:41:04]
John - SC Support - Posts: 38341
This is not something that we can easily answer. The problem is that every service uses a different symbol for each instrument. Therefore, the answer depends on what your service is set to.
When you select File >> Find Symbol, we have done our best to enter the various services symbols. So the first thing to do is to look in that list and see if you can find it. It will be under the CBOT grouping.
The general answer though, is that the CME Group's symbol for this instrument is "30Y".
