Date/Time: Fri, 14 Mar 2025 22:26:43 +0000
Switching to Sierra Chart Teton Futures Order Routing
View Count: 1898
[2021-11-16 16:14:43] |
User420867 - Posts: 1 |
Hello Sierra Chart's Team, I'm currently using AMP as my brokerage, do I need to switch to another brokerage in order to use the Sierra Chart Teton Futures Order Routing? If yes what brokerage do you recommend and what data packages would I need to subscribe to? I only trade futures on CME and would like to have full order book levels. Thank you Date Time Of Last Edit: 2021-11-16 16:18:31
[2021-11-16 17:58:31] |
John - SC Support - Posts: 38678 |
In order to use the Teton Order Routing, you would need to go through Stage 5 Trading as your broker, as they are only ones currently supporting this service. You will find the information on this service along with the Setup Instructions at the following link: Sierra Chart Teton Futures Order Routing In terms of data, you will need to setup the Denali Exchange Data Feed. As to the specific exchange, it is your decision based on your needs. Just make sure you select the exchanges with the Market Depth included in order to get the full order book. Refer to the information for the Denali Exchange Data Feed at the following link (note the Setup Instructions on that page for the CME Group data): Denali Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-12-18 12:52:23] |
AndyBisulca - Posts: 21 |
Prior to yesterday, 12/17/2021, AMP Futures was listed as Intended To Support, or something to that affect, in the Setup Instructions section (bullet #2) on the SC Teton Futures Order Routing page. Yesterday I noticed AMP Futures was removed from the Setup Instructions section). Does this mean the SC Teton Futures Order Routing is not going to be available to AMP Futures clients? Please help me understand what is going on as I have been waiting for this service to be available to AMP Futures customers based on other information I have read from the SC support board. Thank you in advance for your support. |
[2021-12-18 16:40:46] |
We removed from the list, any clearing or broker that does not currently support the service. We only have a statement that they will seriously start to look at this in 2022. So you have to come to your own conclusions. It is a very high quality service which we have full confidence in. There are already several clearing firms and brokers which support it. So obviously just simply move your account if you want to begin to use the service now, unless you are looking for very low margins. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-12-18 16:47:46
[2022-03-06 05:18:39] |
User630795 - Posts: 92 |
guys, if you want AMP to support Teton, we should all pressure them by calling and sending emails demanding. I sent several emails to them telling them i will be forced to move my accounts if they don't offer Teton. They have not responded yet. Send your email today.
[2022-03-06 05:34:07] |
AMP is saying that they want to see over 1,000 accounts on Teton. How many do you currently have using Teton? If it is over 1,000 users, you should let AMP know.
[2022-07-06 13:00:41] |
User888217 - Posts: 2 |
they have maybe 2-3 hundreds.
