Date/Time: Tue, 26 Nov 2024 02:21:43 +0000
Chart Sliding back
View Count: 953
[2014-04-01 15:50:14] |
apollofl - Posts: 95 |
One of my charts keep sliding to the left. What's causing this?
[2014-04-01 17:34:27] |
This would only be caused by user actions. You must be scrolling it back inadvertently. Possibly through a mouse wheel.
[2014-04-01 19:12:13] |
I'll monitor, but i'm not using the wheel nor scrolling.
