Date/Time: Tue, 26 Nov 2024 02:21:02 +0000
TradeDOM playback
View Count: 1202
[2014-04-01 14:02:40] |
User64671 - Posts: 1 |
Hi Support! I am subscribed to the Sierra Chart Real-Time and Historical Futures Data Feed/Eurex. Is there any way to play back the TradeDOM based on previous days data on a tick-by-tick level please? Also to playback the Time And Sales for the same period? Have done a search but can't find any documentation on this. If this is not possible, can I do something similar on the ChartDOM? How to go about doing this please? Thanks in advance!!! |
[2014-04-01 18:39:22] |
Yes all of this is supported. It is documented here: https://www.sierrachart.com/index.php?l=doc/doc_ReplayChart.html#ReplayingTradeDOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
