Date/Time: Mon, 21 Sep 2026 00:58:42 +0000
CASH INDEX
View Count: 887
| [2021-11-15 15:13:48] |
| User529087 - Posts: 25 |
Hi, I would like to have the cash index for RUSSELL, Sp500, and NASDAQ. What are the symbols? on SC, and do I need to activate an additional service for that? Do I get access to the market depth and dom on these symbols? Can I get the ^RUT for the RUSSELL 2000? Can I get access to the corresponding above ETF's? such as IWM for the Russell with dom? Can I get access to the corresponding symbol from above Option chains? Thank you for your really appreciated support. |
| [2021-11-15 16:39:03] |
| John - SC Support - Posts: 47939 |
The information for the Cash Indices can be found here: Real-Time Exchange Data Feeds Available From Sierra Chart: Cash Indexes There is no market depth data for these. You will find the list of indices here: https://www.sierrachart.com/index.php?page=doc/SierraChart_RealTime_And_Historical_Symbols.php&SymbolsPage=Indices If you want to get ETF data, then you would need to use the Sierra Chart Exchange Data Feed and enable the U.S. Equities exchange. Refer to the information at the following link, which also includes Setup Instructions: Sierra Chart Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
