Date/Time: Mon, 03 Mar 2025 21:44:09 +0000
Does market statistics symbol TICK-NYSE require the activation of an specific exchange?
View Count: 643
[2021-11-14 23:51:46]
gsoftinnovation - Posts: 13
Here:
https://www.sierrachart.com/index.php?page=doc/RealTimeDataFeedsAvailableFromSierraChart.php#RealTimeIntradayCashIndexCharts
you can read:
...You will see the particular exchange that needs to be activated after the - character...
and with the TICK-NYSE symbol, I don't see any "-". So my question is, do I need to activate an exchange for the symbol "TICK-NYSE"? Or being subscribed to "Sierra Chart Exchange Data Feed" is enough given that there is no "-" in the symbol?
[2021-11-15 00:22:25]
These symbols are included with all Sierra Chart Service Packages . There is no particular exchange for them. Refer to:
Sierra Chart Market Statistics
[2021-11-15 00:27:59]
Thank you for such a quick reply. Could you pls confirm that I would be needing to add a specific exchange just in the cases that the "-" character shows up at the right of the symbol?
I'm asking because I'm planning to add a few of these market stats and I don't want to be looking at them with delayed data because I did not activate a specific exchange activated.
Thank you one more time
[2021-11-15 15:21:36]
John - SC Support - Posts: 38341
The documentation you referenced is for the Indices. In those cases, you do need to activate the appropriate exchange.
But, you are asking about the Market Statistics, which do NOT require an exchange to be activated. The Market Statistics data is included with Sierra Chart at no additional cost. Refer to the information here:
[2021-11-15 16:11:27]
You are right, my bad ;)
Thank you!
