Date/Time: Mon, 03 Mar 2025 21:55:40 +0000
How to reduce the right margin of a chart?
View Count: 1263
[2021-11-14 00:36:51]
gsoftinnovation - Posts: 13
I want to reduce the amount of "blank" space on the right side of my chart. I'm referring to the amount of space between the most recent candlestick and the end of the area on the right side of the chart.
See attached image, the distance that I'm trying to reduce is in yellow.
imageReduceRightMargin.png / V - Attached On 2021-11-14 00:35:36 UTC - Size: 17.91 KB - 232 views
[2021-11-14 01:12:15]
Refer to:
Working With Charts: Scrolling The Chart and Right Side Fill Space
If the number of bars in the chart is fewer than can be displayed within the chart window, then the only way to reduce the space is to increase the chart bar spacing.
Date Time Of Last Edit: 2021-11-14 01:12:34
[2021-11-14 01:36:15]
JohnR - User831573 - Posts: 317
If you have enough data to fill a screen, then this is another way to control the "blank' space to the right of the last bar visible on the screen.
Working With Charts: Locking the Right Side Fill Space
johnR
[2021-11-14 03:54:11]
Thank you!
