Date/Time: Mon, 03 Mar 2025 21:28:16 +0000
Spreadsheet for Trading does not save spreadsheet
View Count: 709
[2021-11-12 21:09:40] |
User269983 - Posts: 31 |
Tested with SC Version 2328 & 2323 Step to reproduce: 1. Add Spreadsheet for trading to a trade. 2. Input a formula for Buy Exit or Sell Exit (I only use it to manage exit) 3. Switch time frame and the formula will populate all the rows. Actually result: The buy/sell exit field is changed back to blank. Save does not work either If you are using an existing spreadsheet, the formula will reversed back to the original value (*** Note: This value may be different from real actual value if open from a much earlier version of SC, this is my case when open with SC 2215). |
[2021-11-12 23:34:32] |
John - SC Support - Posts: 38341 |
We are not able to reproduce what you are seeing. We tried various situations, but in each of them the data was properly updated and saved. When you enter your formula in the Buy Exit cell, are you not seeing that entry populate down through all the rows when you are done with the cell? Also, what time frame change are you making to your chart? What is the before time and the after time? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-11-15 01:05:23] |
It must be some side affect from some very old configuration settings. I did a new installation and following the transfer guide and the issue persisted. I've resolved this issue with a new installation and transfer only the accounts4 and sierra4 config files. Thanks. |
