Date/Time: Mon, 03 Mar 2025 21:32:33 +0000
Showing a single day only
View Count: 530
[2021-11-12 17:03:10] |
User166108 - Posts: 73 |
I know that it is possible to load 1 day only, but the problem I have is I have a variable period study that needs to look at the last X days/weeks/months. Is it possible to automatically *view* a single session at a time, but back fill X days for studies? The ability to navigate charts session-by-session would be excellent. Thanks |
[2021-11-12 22:33:32] |
John - SC Support - Posts: 38341 |
We are not sure what exactly you are wanting to have in terms of "automatically *view* a single session at a time, but back fill X days for studies". It sounds like you would want to use the Study/Price Overlay where you calculate the study on one chart that has the multiple days/weeks/months/etc. that you want, and then you can overlay that onto the chart that just has the one session in it. Refer to the following: Study/Price Overlay Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
