Date/Time: Mon, 03 Mar 2025 21:44:58 +0000
volume profile
View Count: 561
[2021-11-12 15:10:43] |
chalin saranga jayathilake - Posts: 5 |
hellow i can use tpo indicator 4hour profile and As can be seen in the price action table? i am looking help thank https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=56854 |
[2021-11-12 22:15:59] |
John - SC Support - Posts: 38341 |
We think you are asking to have the Bars displayed at the same time as the TPO profile. This is not supported in Sierra Chart. If it is something else that you are asking, then please give us more information on what exactly you are wanting to know. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-11-13 00:25:29] |
If it is something else that you are asking, then please give us more information on what exactly you are wanting to know. yes sir you are right i want displayed bar,, i can use 4hour profile type tpo indicator? Custom intervals and timeframe period. Monthly, Weekly, Daily, H4 and H1 profiles. With custom periods of Daily, H4, H1, M30, M15, M5, M1 |
[2021-11-14 15:31:08] |
You can have the TPO for various periods and you can control the amount of time for each sub-period. Refer to the following settings for the TPO study: Time Price Opportunity (TPO) Profile Charts: Profile Time Period Length Time Price Opportunity (TPO) Profile Charts: TPO Letter/Block Time Period Length in Minutes (for Intraday Charts) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
