Date/Time: Mon, 05 Oct 2026 21:22:04 +0000
Study Summary: Is there a way to turn off / not show certain symbols formulaically?
View Count: 781
| [2021-11-12 15:02:48] |
| User606491 - Posts: 164 |
I use the study summary extensively in my trading. It's a fantastic tool. Is there a way to turn off / not show certain symbols formulaically? For example, if a symbol does not meet certain criteria, I do not want the symbol to appear on my study summary dashboard. |
| [2021-11-12 15:20:09] |
No, this is not supported. The closest available, is that you can set the text, and background color for a cell for a subgraph used by ACSIL: Study Summary Window: Number, Text, and Color Control for Study Summary Subgraph Cells Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-11-12 20:08:08] |
I understand the complexity in implementing this. Changing background/text color will work fine. Thanks, |
