Date/Time: Tue, 04 Mar 2025 03:46:57 +0000
Web trade account
View Count: 608
[2021-11-11 15:19:44] |
inusuel - Posts: 10 |
I try the web trade account to take a real trade. But no account is assign .how can i do that? Thank
[2021-11-11 16:55:05] |
John - SC Support - Posts: 38341 |
The Web Trading Portal is only for use for the Sierra Chart Order Routing. You are not setup with that service, therefore the web portal will not work for you.
[2021-11-16 23:52:30] |
I am placing some orders each day. IF my computer , or internet goes down during this time . I hope to manage my trade with my cellular . Is the a way to close my trades with my cellular ? |
[2021-11-17 15:05:48] |
Not through Sierra Chart unless you are using the Sierra Chart Order Routing (as we noted above). You could see if your trading service has a mobile app that you can use to access your accounts and make changes that way. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-11-22 13:54:27] |
The new Sierra Chart Teton / Direct Order Routing service does support web-based trading: Sierra Chart Teton Futures Order Routing: Web-Based Trading Panel Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-11-22 13:54:44
