Date/Time: Mon, 03 Mar 2025 18:36:37 +0000
Sierra Data feeds
View Count: 483
[2021-11-11 15:15:36] |
User250571 - Posts: 4 |
Hello, I am in the process of changing to Sierra by the end of November. I am requesting a trial so I can be prepared when I activate the platform live for December. I would like access to Denali and TT for my feeds. I would appreciate the ability to practice getting use to the software so I can make a seemless transition. Please let me know if there is any info you need from me. My introducing broker is Stage 5 and I clear through Dorman. thanks in advance for your help. |
[2021-11-11 16:24:36] |
John - SC Support - Posts: 38337 |
We have reset the trial for your account. We recommend using the Delayed Streaming Exchange Data while you are on the trial and learning how to use Sierra Chart. There is no fee for this data. Refer to the following: Delayed Exchange Data Feed Otherwise, it is not possible to get real-time data from us during the trial. You would have to change to a paid package to get the real-time data. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
