Date/Time: Mon, 03 Mar 2025 18:35:43 +0000
My e-mini s&p 500 chart not loading?
View Count: 621
[2021-11-11 13:39:01] |
bayojr17 - Posts: 2 |
My e-mini s&p 500 chart has not loaded since last friday? I have deleted all data and downlaoded it, but now nothing comes up? And my account is still active for 9 more days?
Date Time Of Last Edit: 2021-11-11 15:59:22
Private File Attachment Deleted. Private File |
[2021-11-11 15:03:25] |
You need to activate the exchange you require here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed Once that is active, It will go into effect in 2 to 3 minutes. And then you should have the data. You may need to restart Sierra Chart though. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-11-11 15:03:36
