Date/Time: Mon, 03 Mar 2025 18:15:38 +0000
New to Sierra data feeds
View Count: 514
[2021-11-11 01:15:47] |
User250571 - Posts: 4 |
I am in the process of changing to Sierra where Denali will be the data feed and TT will be order routing. however, I read that TT and CQg is not recommended to use. Which routing service is available to me and what would Sierra recommend? I clear through Dorman. I was told by my broker, apparently erroneously, that the Denali and TT combo works very well with ultra low latency, but that statement is not supported by this message board. Low latency is my main priority at the moment. Please advise on the best course of action. thanks in advance for your help. I have experienced frozen doms with another provider which cost me a lot of money. I am will to pay for the best, but I need some guidance. It appeard at the moment, the only 2 options are CQG and TT. help please!! |
[2021-11-11 15:01:39] |
TT is being phased out by us. You will want to use our new direct routing: Sierra Chart Teton Futures Order Routing The direct routing is in the process of being supported by Dorman and should be available, in December. Or you can use it now through Advantage. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-11-11 17:35:13] |
Will I have access to Sierra order routing if I start my services with sierra by the beginning of December?
[2021-11-11 17:38:13] |
John - SC Support - Posts: 38331 |
We are assuming that you are asking if the new Sierra Chart Teton Order Routing will be working with Dorman by early December. The answer is that we do not know. We certainly hope so, but since there is work to be done on both sides, we can not say when exactly it will get done, until it actually gets done. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
