Date/Time: Mon, 03 Mar 2025 18:39:58 +0000
Scroll Volume By Price
View Count: 497
[2021-11-10 22:27:44] |
Technical - Posts: 158 |
I have a chart built with seperate VBP studies for evening and day sessions. If I scroll l/r now the VBP study does not change. If I set the "Volume Graph Period Type" to "Visible Bars" it seems to build the VBP study as I scroll however the VBP study graph no longer represents the day session only. Is it possible to scroll left/right and observe the VBP study as it builds while maintaining separate evening and day sessions? |
[2021-11-10 23:02:03] |
John - SC Support - Posts: 38337 |
What you are wanting is not supported. The only way to "kind of" do what you are wanting is to setup the Volume Profiles for the separate Day and Evening sessions and then use the Replay function to replay the bars to see the VbP building up. Refer to the following for replaying a chart: Replaying Charts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
