Date/Time: Mon, 03 Mar 2025 18:15:00 +0000
Market by Order - MBO on second/third instance
View Count: 494
[2021-11-10 20:42:44] |
DayTraderEsad - Posts: 121 |
I am trying to add MBO data to my DOM's to show up on the second and third instance and it simply does not pull anything. I have the server setting set as subscribed on each instance and it is still not pulling anything in the MBO column on the DOM. It does pull the MBO data on the DOM's that are on the main SC platform, just not working on the instances. How can I get it to work on the instances as well? |
[2021-11-10 22:59:48] |
John - SC Support - Posts: 38330 |
The MBO data is not sent to the Sub-Intances, therefore you can only get it in the main instance. This is on our list of changes to implement, but we have not had a chance to get to it yet. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
