Date/Time: Mon, 03 Mar 2025 18:18:06 +0000
Drawing tools in linked charts
View Count: 728
[2021-11-10 19:08:03] |
countryboy92 - Posts: 91 |
I would like to draw retracement lines on several linked charts at the same time; I am drawing the same retracement zone on several tick or time charts for the same symbol. Is there a way to do this?
[2021-11-10 22:23:14] |
John - SC Support - Posts: 38333 |
You can copy the drawings from one chart to another. Refer to the following: Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
