Date/Time: Mon, 03 Mar 2025 17:55:47 +0000
Session Times from imported Chartbooks incorrect
View Count: 487
[2021-11-09 21:52:36]
User391959 - Posts: 17
Dear Sierra Support Team
I am using v2315.
Copying SC Chartbook File *.Cht from another SC user in my 'data' folder.
Opening the *.Cht Chartbook in my SC instance.
>> session times from all charts within this chartbook are automatically set to 00:00:00 start to 23:59:59 end time.
>> these session time settings are not in line with what the previous user has defined in his chartbook (e.g. 18:00:00 to 16:59:59 NYC).
Since I here from other users that they import the *.Cht chartbook with correct session time settings, I assume that in my SC instance the session time settings get automatically overwritten.
Is there anything I can do in order to be able to import *Cht files with original session time settings? (e.g. global time/date settings, symbol settings, etc.?)
[2021-11-09 22:30:47]
Refer to:
Chart Session Times: Session Times Automatically Changing Unexpectedly
