Date/Time: Mon, 03 Mar 2025 17:41:35 +0000
diagonal delta on numbers bars?
View Count: 632
[2021-11-09 18:20:41]
HeyUgly - Posts: 251
hello
experimented with most settings, curious if theres a diagonal Delta for the number bars setting?
tried most settings, but nothing matches my delta study that runs beside it pic attached shows diagonal delta trying to match this in number bars
imageCapture.PNG / V - Attached On 2021-11-09 18:20:10 UTC - Size: 66.54 KB - 164 views
[2021-11-09 18:46:08]
John - SC Support - Posts: 38325
Set the Column 1 Numbers Bars Text to Ask Vol Bid Vol Diagonal Difference. Refer to the following:
Numbers Bars: Numbers Bars Text Types
[2021-11-09 19:21:42]
so i guess my next question is with this setting, is there any way to JUST have the delta show up in the number bar, not both sides. so the delta study on the right, , i want it to JUST show the delta, not the bid/ask, just the delta thats calculated, pic attached
imageCapture.PNG / V - Attached On 2021-11-09 19:21:31 UTC - Size: 19.29 KB - 164 views
[2021-11-10 12:00:05]
all im trying to do is see the delta, and have the bar colored blue or red for + or negative delta, its close but i dont want to see both sides, just the overall delta at each vol multiplier lvl, so i can watch the flow of the delta as price action comes in
Date Time Of Last Edit: 2021-11-10 12:00:25
imageCapture.PNG / V - Attached On 2021-11-10 12:00:22 UTC - Size: 22.08 KB - 156 views
[2021-11-10 15:42:07]
There is not an option for this in the Numbers Bars for the Diagonal Delta.
We have marked this as a Feature Request.
[2021-11-10 15:52:21]
thank you! i would very much appreciate that!!
