Date/Time: Sat, 19 Sep 2026 07:04:04 +0000
Stock data feed
View Count: 873
| [2021-11-09 17:53:54] |
| User329455 - Posts: 26 |
Hi, I’ve been using the Denali data feed for a while to trade CME futures. I would like to get US Equities (NYSE, NASDAQ, AMEX) data as well to chart stocks. On the Exchange Data Feed Features page (https://www.sierrachart.com/UserControlPanel.php?page=ExchangeDataFeedFeatures#SetCountryState) in the Real-Time Data Connections section it says “If you require data from CME/CBOT/NYMEX/COMEX or EUREX You need to use the Denali Exchange Data Feed’. If I activate the ‘250 real-time symbols’ service, will I need to change anything in Sierra Charts to begin using that data? Will it affect my ability to trade CME futures?
| [2021-11-09 18:43:10] |
| John - SC Support - Posts: 47939 |
You can have both the Denali Exchange Data Feed and the Sierra Chart Exchange Data Feed running at the same time to the same system. Refer to the following: https://www.sierrachart.com/index.php?page=doc/RealTimeDataFeedsAvailableFromSierraChart.php#UsingBothDenaliExchangeDataFeedAndSierraChartExchangeDataFeed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
