Date/Time: Mon, 03 Mar 2025 17:24:46 +0000
[Programming Help] - Live data with Denali data feed
View Count: 644
[2021-11-09 17:53:18] |
User716295 - Posts: 3 |
Using Denali data feed with Amp Futures I receive delayed data (Current selected service = SC Data - all services) but not live data. Using SC Futures Order Routing I get "Error Connecting" and no data. I contacted Amp again and was told they "don't support direct CME order routing service." Instead, I was set up with CQGWebAPI for trading. Isn't CQG the service you found not reliable? Should I just go to another broker? Any recommendations? (At least I do have live data now.)
[2021-11-09 18:41:51] |
John - SC Support - Posts: 38319 |
It's really up to you. Our biggest gripes are with the data from other providers, so as long as you are using the Denali Exchange Data Feed with CQG, you should be OK. But, if you are only trading the CME Group, then you can consider moving to the Teton Order Routing Service. The information for this can be found here: Sierra Chart Teton Futures Order Routing For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
