Date/Time: Mon, 03 Mar 2025 17:44:57 +0000
dynamic horizontal line
View Count: 485
[2021-11-09 15:21:00] |
User299107 - Posts: 59 |
Hi guys, at present the "current price line" can only relate to OHLC etc. Is it possible to have a horizontal line across the historical intraday chart which is based on a user variable eg mid. If this can be done it would be GREAT (for me). Thanks, Eliza |
[2021-11-09 16:07:37] |
John - SC Support - Posts: 38326 |
You can do this using the Spreadsheet Study. Just make sure you use Absolute References to the cells so you get the same value for an entire column.
