Date/Time: Mon, 03 Mar 2025 17:43:49 +0000
Problem with Number Bars Calculated Values 2 Study
View Count: 598
[2021-11-09 07:26:27]
User486817 - Posts: 83
hello,
i am using the Number Bars Calculated Values 2 Study on an intraday chart. Sum Bid Pull/Stack(SG7), Sum Ask Pull/Stack(SG8) and Ask/Bid Pull/Stack Sum Diff(SG9) all display zeros. in "Settings and Inputs" i have "Show Pullback Column Values" set at yes. The pullback column for other SGs works fine, and data displays for other SGs. however, "0" is displayed for the above SGs in all columns. how can i fix this?
kindest regards,
[2021-11-09 15:04:03]
John - SC Support - Posts: 38326
You have to have added at least one of the Pulling/Stacking columns to the DOM in order to get the values to start showing up in the Numbers Bars Calculated Values 2 study.
Refer to the following for how to add columns to the DOM:
Global Trade Settings Windows: Customize Chart/Trade DOM Columns (Chart Specific)
