Date/Time: Fri, 07 Feb 2025 15:23:34 +0000
suggestion for Volume setting
View Count: 441
[2021-11-07 20:45:55] |
Kefir - Posts: 34 |
Hello, I would like to display volume on intraday (1 min) chart with volume in the Chart region 2 however I would like the volume to be displayed only for current day. The reason is that high volume trading in the last minutes of previous day (RTH ... settlement time) expands scale and therefore I don't have easy - quick look at the volume of current bar comparing to previous bars of today. I want to see price chart of previous day but not volume of that day. If you could incorporate setting for how many days back should the volume be displayed with 1 being current day it would be nice solution for me. Or if you have another easy solution how to display volume only for today I would appreciate your ideas. Kind regards r. |
[2021-11-08 15:07:35] |
John - SC Support - Posts: 37810 |
You could use the Spreadsheet Study or the Color Bar Based on Alert condition to force the condition of only showing the Volume from today. The Spreadsheet would probably be the easiest, as you would use the following Formula in cell K3: =IF(INTDATE(A3) = TODAY(), ID0.SG5@3, 0) Then just change the display for Subgraph K to Bars and any other settings as you need. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
