Date/Time: Tue, 26 Nov 2024 03:53:57 +0000
cts orders and positions trade stats...
View Count: 1105
[2014-03-31 16:44:02] |
User53765 - Posts: 66 |
Hi Sierra Support, Im in a practice account with Topsteptrader and im looking at my trade stats using the sim server but without simulation mode on Sierra. There is nothing showing up on the newer versions of sierra releases but the older versions I still get the live stats. Is there any way to fix this? Thanks in advance. |
[2014-03-31 17:11:17] |
Check the settings at the top of the Trade Activity Log. Follow through the instructions here: https://www.sierrachart.com/index.php?l=doc/doc_TradeActivityLog.php#ViewingHistoricalTA Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
