Date/Time: Mon, 03 Mar 2025 17:32:16 +0000
Using a filter on number bars
View Count: 461
[2021-11-06 12:04:56] |
User525965 - Posts: 153 |
Hi, I would like to filter out trades in number bars that have less than 600 lots traded. See example below. How could I do this? Would I change the bar period type under chart settings? Or would I change a setting in the number bar indicator it self. Thanks! |
![]() Attachment Deleted. |
[2021-11-07 15:16:06] |
John - SC Support - Posts: 38321 |
You need to use the Filter options in Chart >> Chart Settings >> Advanced Settings 2 >> Volume Filter. Refer to the following: Chart Settings: Volume Filter (Chart >> Chart Settings >> Data Limiting >> Volume Filter Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
