Date/Time: Mon, 03 Mar 2025 17:15:00 +0000
Is it possible to see a order and/or a fill within the a Spreadsheet study?
View Count: 722
[2021-11-06 10:52:12] |
User230940 - Posts: 121 |
Hello, is it possible to get the input of an Order and/or an Fill inside a spreadsheet study? Thanks regards carsten |
[2021-11-07 15:14:11] |
John - SC Support - Posts: 38313 |
With the Spreadsheet System for Trading there is some information available in columns I and J that are related to the current and the prior orders. But if you are asking for the information in the regular Spreadsheet Study, then you can get the order information by using the Trade Data Studies. Refer to the following: Trading Information Windows: Trade Data Studies For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-11-08 09:33:33] |
Hi, thanks. I would like to have the Trade information in a Text File, which will be stored regular, like possible with the Spreedsheet Study. This would be possible via Trade activity Log, but can not be stored automatic regularly in Text Format. Is there a way to get the trade information (Order, Order Fill) in regularly in a text format? Thanks regards |
[2021-11-08 15:20:53] |
There is not a built-in way to do what you are asking for.
[2021-11-08 18:38:52] |
The SpreadSheet Syetem/Alert is closed source, isn`t? regards |
[2021-11-08 20:22:40] |
Yes it is.
[2021-11-09 12:43:07] |
Is there a example study with store to file function? regards |
[2021-11-09 15:08:48] |
We are not sure exactly what you are looking for, but there are lots of example files on your system, as we send them out with the installations. They are located in the ACS_Source folder just under the main Sierra Chart installation folder. For more information on these files and searching them for something specific, refer to the following: How to Build an Advanced Custom Study from Source Code: Searching for Source Code for Sierra Chart Built-In Studies For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-11-09 19:58:33] |
Hi, I was looking for an example howto store data to a text file. regards |
[2021-11-10 03:19:24] |
To access the data you need, you need to use ACSIL and use the functions available here: Automated Trading From an Advanced Custom Study And there are functions for writing to a file: ACSIL Interface Members - Functions: sc.OpenFile() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-11-10 03:19:53
