Date/Time: Tue, 26 Nov 2024 02:47:27 +0000
Study Question
View Count: 1133
[2014-03-31 16:38:19]
infpz - Posts: 826
Is there a study I can apply to a Range/Renko chart that will display what the high/low of the next bar will be as soon as it is created? For example, with a range chart of 4 ticks, as soon as that bar is painted, I want a line where the high and low will be. Since it's a range bar, that high/low should be immediately available, I just want to display them as line somehow.
[2014-03-31 17:26:07]
You can use the Range Bar Predictor study:
http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s235
[2014-04-04 18:23:19]
infpz - Posts: 826
Seems like on a Renko Chart it just plots the highest high and lowest low of bar. Is there a way to have the high and low printed before they are reached, since the software knows where they are going to be?
[2014-04-04 18:37:27]
The Range Bar Predictor study does not work with a Renko chart. Only for Range bars.
[2014-04-04 18:39:04]
infpz - Posts: 826
OK. Is there something similar available for a Renko chart?
[2014-04-04 21:16:35]
We will add a Renko Bar Predictor study to the next release.
[2014-04-04 21:29:39]
infpz - Posts: 826
I will notify my customer.
