Date/Time: Sun, 06 Jul 2025 02:54:59 +0000
custom study file name bug
View Count: 477
[2021-11-05 04:11:05] |
User4761 - Posts: 9 |
FYI, just discovered that if a custom study dll has an underscore in the name prior to a digit (other than the default _64) it will not show up in the add custom study box. IE "_1_64" is not a valid name and sc thinks the file is missing. This bug started a few months back and I've only just worked out the problem. Also im using v2274 so if this has been fixed since, please disregard. fred |
[2021-11-05 13:56:43] |
What you are referring to is considered the version number which can be in the filename. Example: DLLName_2151_64.dll Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-11-05 14:49:16] |
Sierra_Chart Engineering - Posts: 20089 |
This actually is clearly documented here: Advanced Custom Study Interface and Language (ACSIL): Custom Study DLL File Name Format Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
