Date/Time: Tue, 29 Sep 2026 05:02:12 +0000
Move to Package 10
View Count: 825
| [2021-11-05 03:35:11] |
| User471548 - Posts: 29 |
Hi, I have recently decided to focus on CME and CBOT, and not trade Eurex anymore. I trade the order flows and is currently on package 11. Would there be any impact if I move to package 10? If not, how should I move with minimal disruption? Thanks. |
| [2021-11-05 13:30:39] |
| John - SC Support - Posts: 48044 |
To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link. Or go to this page: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation You will need to login if you are not currently logged in. In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button. The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price. There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted. ------------------- Just so you are aware, Package 10 does NOT include the Numbers Bars study. So if you are the Numbers Bars for your Order Flow, then you will need to stay on Package 11. Refer to the differences in the packages here: Description of Service Packages and Pricing: Packages For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
