Date/Time: Mon, 03 Mar 2025 18:40:42 +0000
AMP + TTW
View Count: 593
[2021-11-04 15:36:08] |
Jia T P R - Posts: 26 |
Good Daym TTW + AMP still possible? If yes how? Kind regards |
[2021-11-04 15:44:55] |
John - SC Support - Posts: 38337 |
If you are asking about the Sierra Chart Order Routing Service with TT, then that option with AMP is not available. AMP stopped support for that option earlier this year.
[2021-11-11 15:03:13] |
Is there a Broker you could recommend?
[2021-11-11 15:52:47] |
Right now the only broker that has support for our Teton Direct Order Routing is Stage 5 in combination with Advantage. For more information on this service, refer to the following: Sierra Chart Teton Futures Order Routing For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
