Date/Time: Mon, 03 Mar 2025 10:51:07 +0000
Problème de stop loss
View Count: 554
[2021-11-04 11:01:24] |
User525038 - Posts: 14 |
je pose une position avec un take profit et un stop loss, quand le cours du support évolue le stop se déplace mettant en danger ma position, ou est l'erreur Cordialement |
[2021-11-04 14:06:43] |
John - SC Support - Posts: 38292 |
I place a position with a take profit and a stop loss, when the support price moves the stop moves endangering my position, where is the error
Regards There are a few possibilities. First, if the parent order is a pending order waiting for some event, then when the parent fills, by default, the child orders are going to maintain the same offset that was initially set. Depending on where the parent fills relative to the original price point, the child orders would then move. Refer to the following setting: Global Trade Settings Windows: Adjust Attached Orders to Maintain Same Offset on Parent Fill (Global Settings >> General Trade Settings >> General) Second, depending on the Stop Loss type of order, it could move. For instance, if it is a Trailing Stop Loss. Refer to the Order Types information at this link: Order Types For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
