Date/Time: Mon, 03 Mar 2025 10:52:57 +0000
[User Discussion] - Chart template feature request
View Count: 497
[2021-11-03 16:59:01] |
Trader & Sierra++ developer - Posts: 110 |
Hello Sierra, Your documentation says "The various duplicate chart functionality is the only method by which you can use a chart as a template to create another one. There is no other method." After having spent weeks dealing with charts & studies for 4 symbols, I feel a bit discouraged of doing any new change, and I hesitate to add more symbols as it would lead to even more time lost on each small change of a chart or study setting. The "Duplicate chart" feature is useful, but cannot replace an important feature that is missing : a global chart templating system accross chartbooks. My question is : Do you plan to add a chart templating feature, so that a change in a template or in the master chart (owner of the template) is instantly applied/copied to all other charts linked to that template accross chartbooks ? And when ? Thank you Date Time Of Last Edit: 2021-11-03 18:14:48
